Group: DynoMotion Message: 13845 From: David Strip Date: 10/12/2016
Subject: Spindle control - Jogging Spindle 0.000000 counts/sec
Attachments :
    I'm trying to implement spindle control as outlined in the guide.
    Spindle is a brushless DC motor with encoder, configured on channel 4.
    (CMD, jog4=2000) gets the spindle turning at the right speed, so I'm pretty sure the channel is correctly configured
    MySpindleDefs.h contains:
    #define SPINDLEAXIS 4            // Axis Channel to Jog to rotate Spindle
    #define FACTOR (4000./60.0)      // to convert RPM to counts/sec (counts/rev / 60.0sec)
    #define SPINDLECW_BIT 154       // bit to activate to cause CW rotation
    #define SPINDLECCW_BIT 155        // bit to activate to cause CCW rotation
    #define SPEEDVAR 99                // global persistant variable to store latest speed
    #define STATEVAR 98                // global persistant variable to store latest state (-1=CCW,0=off,1=CW)
    #define KMVAR PC_COMM_CSS_S    // variable KMotionCNC will pass speed parameter (113)
    #define USE_POS_NEG_VOLTAGE 0     // 0 = output Magnitude, 1 = output positive and negative speed
    The tool setup screen looks like this:
    If I issue an M3 or click the "on cw" button on KMotionCNC, the console shows "Jogging Spindle 0.00000 counts/sec.
    If I issue M5 of click off, I get Jogging Spindle Stop.
    Hence, the programs are being run, but they apparently are not getting the Spindle speed.
    I expect I'm missing something painfully obvious, but am not seeing what it is.
    Group: DynoMotion Message: 13847 From: TKSOFT Date: 10/12/2016
    Subject: Re: Spindle control - Jogging Spindle 0.000000 counts/sec
    Configure the Var for your S Action to use 113 not 99.
    113 (KMVAR)is where the S program is expecting to receive the new speed
    from KMotionCNC. 99 is used to keep track of last commanded Speed
    communicated between the various C Programs.
    On 2016-10-12 12:32, David Strip David@... [DynoMotion]
    > Spindle
    > rotation
    > rotation
    > store latest speed
    > parameter (113)
    > the Spindle speed.
    > what it is.
    Group: DynoMotion Message: 13848 From: David Strip Date: 10/12/2016
    that solved it.
